Baz1150
Full story is, battery was getting a bit dire stating my 2011 tc R1200GS so went for an oddesey as i do a fair few short journeys (10 miles) so want to makesure i have plenty of cranking power.
Battery arrives and fitted no problem, done the TPS reset but now when shes cold the bike runs lumpy at tick over revs rising and falling like its trying to stall but then catching itself but if i ride off on her the revs wont drop below 3000rpm when i try to change gear, almost as if the throttle is stuck, when ii close the throttle the revs wont drop, do a couple of miles then it sorts itself out and runs no problem apart from back popping through the exhaust every time i throttle back, though to be fair it did do this a bit before.
I checked the tank breather was not kinked and i did a second tps reset but the bike is just the same. Have i done something unwittingly to the bike? or is there something i need to do or has it got to go into the dealers to be sorted?, I never had any problem apart from the odd popping from the exhaust before i changed the battery.
Any suggestions or advise please.
P.s I have done 200 miles since i changed the battery.
