Africa twin?
I'd say the biggest thing to look out for is the output shaft which can get buggered if the bike has been run with the chain too tight. The only other common issue is the fuel pump can fail but this is an easy and cheap fix (facet) - saying that I've ran mine for 60k miles with no problem. Have a look at xrv.org.uk which is the fount of all AT information.
+1 for above comments and xrv.org.uk. Not much else really except corroded wheel rims on older models. Mine has only had the regulator go.
Thunder of this parish has a good thread on xrv about his blingy rebuild
