Airhawk valve repair
sparkplug
Landlord
Mod Squad
Moderator
Solutions
3
second from the left, third from the right
After many years of (ab)use my trusty early model airhawk gave out the other day.
The problem was that the rubber around the bend of the valve had cracked - no way of getting a patch onto it :(
Before giving it up for dead - I tried using the coating material we use to seal earplugs with.
A few coats produced a perfect repair - It's only done a short run so far but seems fine.
If you have the same problem then I'll happily do the repair FOC (just cover the postage) :thumb2
Should add that this is the neoprene - I don't think it would work on the budget models..
