BiG DoM
Recently made a nifty airpump mod to the GS! ....
this will though only work on non-ABS models (quite popular here with much riding
on gravel and dirt)... Under the gastank in the space that would otherwise house the ABS unit I have fitted a quality mini-compressor/12V airpump - the type available from most auto spares stores for 4X4's(not the real cheapy that does not give me enough pressure). This unit fits perfectly sideways into the space, has rubber grommets on 'feet' and bolts easily to base plate. The hose is coiled under the RHS sside cover. VERY useful
when having reduced pressures and needing to re-inflate when in the rough etc.
Seeing one is no longer able to post attachemnts here you will nedd go here for pic!!:
http://www.advrider.com/forums/showthread.php?s=&threadid=9881http://
