z900guy
Hello
I have just fitted alloy wheels into my 2000 gs 1150 and noticed that the ABS rings from my wire wheels are mounted on seperate lugs to the disc bolts whereas on the alloys the abs ring sits behind the disc bolts
Simple enough to swap over except the abs rings from the wire wheels have a smaller hole than the disc bolt so do I drill em out or do i need the ABS rings from the alloy wheels ?
Chris
Chris
