Alternative inner bags x Zega
  • Thread starter Thread starter Theo
Theo
Hi,
I'm looking for two inner bags for Touratech Zega panniers... the Original Zega Bags are so expensive!! :(
Do you have some ideas???
I was thinking at the ski boots bag but is smaller than the Zega case....
Hi
I bought a set of custom inners from somewhere a while back and never use them bacause they were a pain to pack and rather impractical to use.
I found sack type bags the best because they could be forced into the panniers more easily than a pre-shaped item.
Bearing this in mind, I spent an evening searching for an alternative and think I have found a solution. Compression sacks. Similar to the way a modern sleeping bag is packed: with pull down straps to reduce the overall storage area. Fine for clothing like fleeces etc. Not much good for an ironed shirt though!
I have ordered 2 of them (at £8 each it's worth a punt.)
hirebikeandride.com
JerryP said:
Hi.... Compression sacks. Similar to the way a modern sleeping bag is packed: with pull down straps to reduce the overall storage area. ...
Good idea! 2 sacks for each panniers may be a solution! :thumb
I've got my mum making me two out of goretex. I'm picking them up next wk so if they look reasonable i'll post a picture and you could negotiate with her for a set :)
