Ijustwanttoseethephotos
A customer's gearbox arrived this morning for an overhaul and re-shimming, (1991 R80RT).
It was obvious from the amount of sealant that someone had been inside the 'box before.
The output shaft is the non circlip type which had obviously bothered a previous owner, because, to fix the bearing
in place, he has welded the bearing inner to the shaft!!!
Never a dull day with gearbox rebuilds!
