alternatives to Daytona M star GTX boots
chasbmw
bath UK
Being a bit short of leg, I'm thinking that it might be useful to get some built up boots as they should make it a bit easier to get my ageing hips on and off the bike.
Ive taken a look at the Daytona M star boots, which look as if they might do the business, but not cheap, i have emailed Altbergs to see if they can do anything. Has anyone used the Daytona boots and do they work? What alternatives are there.
Many thanks
Charles
Both good boots; all depends what your riding.
I've got the Evo Voltex and GTX goretex which are both excellent. However, if you were wanting them built up slightly, it'd be Altberg I'd be talking to first.
Sent from my GT-N7105 using Tapatalk
Many thanks
Charles
I have had the Daytona Ladystar boots, which are equivalent to the M Star. They have an insole which is built up at the heel, but the toe end is just normal thickness, so they don't actually give you much advantage other than having a bit more of the back of your foot on the ground. You don't get more 'reach' at the toe, if you see what I mean.
I also have some Altberg Hogg Lights. They provide more advantage in their standard form than the Daytonas as they have a thick sole over the whole length of the boot. I did try having some extra height built into the sole, but they were then too stiff, caused problems with the gear change and looked like a pair of 1970's platforms :rolleyes:
The Altbergs are considerably cheaper than the Daytonas, have a better sole and are warmer in the winter.
Other boots to consider include the Sidi Armada or others in the Sidi range, which also have a thick sole as standard.
Hope this helps :)
I am a great fan of Daytona, but they are a tad expensive these days & are probably due to rise even further.
However we found SWMBO a pair of Ladystar GTX on eBay. Barely worn, ever, for under £40 delivered. Beautiful boots, but the raised sole does make them quite heavy & a mental adjustment is needed to avoid her, as a pillion, kicking the seat/panniers. I'm not sure how this would impact on gear changing or rear brake feel, on the front.
So, my conclusion as a rider is that I think I would look at alternative ways to achieve the desired comfort level. Lower the seat, adjust the suspension; even change the bike. Each to their own though, whatever works best for you.
I have a pair of Daytona Ladystar and yes as said the height is mainly in the heel. But there is a small increase in the sole by approx the thickness of the sole, if that make sense
I've got the M stars but more to be able to get more of my foot on the ground when stationary-as above they add about 25mm to the heel, but around 8mm to the ball so your foot is at a slightly different angle, but you get used to that. They're very comfortable and if you do decide to get some look at FC moto. If you register then add them to your basket, but don't buy them you'll get an email offering you 10% off
I have the daytonas. Definitely feel like I can get my feet more planted when wearing them. The boots are totally superb and one of my best ever purchases.
