After 2 fairly recent g'box re-builds, my 'box has now refused to allow me to select 1st gear. Consequently the 'box is with Steve Scriminger, to havethe selector internals inspected (100 GSPD paralever).
The esteemed Mr S suggested that fitting an adjustable torque arm to the paralevers, when adjusted correctly under rider and luggage load, should help to flatten the sharp angle suffered by the UJ at the bevel box end of the shaft.
So, bowing to superior knowledge and experience, I have tried to hunt down an adjustable torque arm - tried all the usual suspects, HPN, Moren Israeli, BMWBoxer Parts, BoxerParts etc., to no avail.
Does anyone have any experience of such an arm, or where, if anywhere, it is possible to buy one ?
Much though I love my GS, there is no doubt in my mind that the shaft and gearbox are the weakest link on the paralevers. Clearly the shaft was the earliest iteration of the paralever design,and as such, over reasonable mileages, proves to be over stressed due to the angles involved, and from the sliding/hammering from the splines/UJ's. Apparently the 1100's and 1150's had the splines further up the shaft, and as such took some of the stresses away from the bottom UJ.
Discuss.......
PS Before anyone mentions it, yes I have an Ohlins, but yes, I have had it shortened to same length as standard BMW GS shock length. This obviously reverts that angle back to standard.
Discuss.......
