AC-90 is an industrial spray lubricant. AC-90 does not contain Silicone or CFC’s. AC-90 will penetrate and release rusty and/or jammed components. AC-90 displaces moisture from vehicle ignitions systems and aids starting and smooth running. Simply spray AC-90 over the exterior of all distributor leads, spark plug leads and all electrical components to prevent moisture induced faults.
AC-90 cleanly lubricates and restores smooth, silent operation to hinges, locks castors, drawer runners, and curtain tracks. AC-90 multipurpose lubricant will stop sticking and squeaking. AC-90 cleans all metals and removes bloom from enamel surfaces such as fridges, cookers, and stainless steel sinks. AC-90 removes dirt, grime, lime scale, crayon marks, chewing gum, and adhesives. AC-90 degreases and leaves an anti-rust protective film. AC-90 is ideal for protecting metal components during storage or manufacture. De-scales taps and showers. Does not conduct electricity within the normal range found in home or industry. AC-90 is the perfect multipurpose lubricant cleaner formulation for all around the workshop, garage, and factory. Unlike other multipurpose industrial spray lubricants.
AC-90 does not contain Odourless Kerosene which can give rise to skin problems. AC-90 is available in various size aerosols, with both standard propellant and with a special non flammable propellant which is Ideal for use in some industrial locations where a flammable propellant aerosol is considered inappropriate. AC-90 is also available in 5/25/200 litre drums available with a purpose made applicator which has all appropriate health and safety data printed on the body of the applicator. AC-90 Multipurpose lubricant is approved for quality by Jaguar Cars Limited, J.C.B., Audi Volkswagen, and British Gas. AC-90 formulation is the only lubricant /cleaner product approved by A.E. Technologies for use on the UK National Grid electrical system.
