bashan
Hi guys,
Recently I had moved to a colder climate (SE Michigan, US), and while at home the bike is garaged I do not have that privilege at work. Unfortunately, during the day the bike is parked outside. Today I had to remove some snow from the seat before heading back home. The outside temperature was in the high 20’s (-2[c]) and it was very hard to convince the bike to start running. The bike would either start running after 2~3 seconds of a starter help and then would immediately shut itself down, or I could hold the starter for 10 seconds without ignition. Finally, after about 7 trials I was able to hit the throttle within the few seconds that the engine was running to get it to higher revs (3k~4k) and this way keep the engine running. All the ignition attempts were done with the throttle in the off position while the starter button is being pushed.
So, is this the way it is suppose to be? Am I doing something wrong? Is it just hard to get it running in a cold weather?
Please don’t tell me not to ride in a cold day. I’m to be able to ride the bike at least until the roads would be covered with ice (probably another month).
Thanks,
Eran.
Thanks,
Eran.
