AT Wind deflectors from Rugged Roads On ebay cheap
Ordered, Thanks for the heads up Rob:thumby:
Ordered thanks Rob! Hope you are well.
Sent from my SM-G928F using Tapatalk
No worries guys
All good Georgeeboi thanks matey
Mine arrived yesterday and was fitted albeit no chance of getting out on the bike in this crap weather I hope it helps
Rob
Mines Arrived..great bit of kit :beerjug:
Steve
I'd like to see an engineering report on how it effects airflow through radiators, positive and negative air pressure can be a bitch in the wrong places.
Don't know about you lot but the holes on mine did not line up, really pisses me off when things don't fit properly as there is a fair chance of threading a bolt, had to elongate the holes in the end after removing several times (dropping bolts and spacers which took longer to find than fitting the feckin thing :mad:) Hopefully if will have a noticeable effect :nenau
Yes it was a bit of a tight fit I had to align the rear bolts first, it may be there is some play in ther paneling positions ergo the alignment problem.
