autocom 4044 lead
The four pole end goes into the Aux #2 socket on the Active Plus. The three pole end should go into the 3.5mm socket on the Garmin loom.
Obviously, you're aware that this set-up is going to give you audio out from the Garmin only (music and directions)? The #4066 lead can theoretically mean that you can use the phone though the Zumo as well. However, due to kit I already had, I wound up with the phone on a separate Bluetooth connection myself, no great loss TBH as the phone connection is only for emergency incoming calls only. Did buy a 4066 at the NEC but never got around to fitting it and sold it recently.
Thanks Bumpkin, that helps. I did buy the 4004 lead on purpose as I really don't want phone calls on the bike, and as you say I could bluetooth it needs must.
