db1
Hi,
I am about to fit the following to the R1200 GS, and based on the various threads here it seems using the manual holder is the optimal place. What I am wondering is whether the BT adaptor could be mounted under the seat and still work effectively with the Zumo & phone. Has anyone tried this?
As I am doing this myself and am somewhat inexperienced the fewer things I can avoid moving/removing the better.
I am guess that the (better) alternative might be to mount this under the "beak" in the front with some velcro and then run the cables under the tank back to the manual holder. I think this means taking most of the trim off the bike to achieve this. Is this straighforward? Any "gotchas" to doing this? Apart from cable ties what other useful bits and pieces do you recommend?
Lastly, the Autocom currently powers off a 9V battery to allow me to move it between bikes, any experience in how long this would last when powering the BT adaptor as well as the headsets etc?
Cheers and thanks for any help!!!
DB1
DB1
