Not sure about the quiet quest side of things...
My UltimateEar monitors turned up last week and it finally prompted me to wire everything up properly taking a feed off the fusepanel with one of BlackDragon's widgets. (And some prior convincing from Steptoe that the fusbox lid really does fit thru the frame rails). 2 hrs of removing the old powersocket/autocom feed off the abs, and putting it all together nicely again got everything working a treat.
<b>Except: Now the quest is way too loud.</b>
Even on '1' I have to cut the signal right down to 5-10% on the UE volume to get it
right (no distortion,busted eardrum, CPU whine, or spark whine).
If I use the Zen micro player I can get a nice balance at about 80% on the UE monitors and 60% on the zen, but the quest if turned on would be making a terrible racket.
It's Quest->touratech lead with the power plug chopped off and wired to switched source.
Audio cable runs next to it, I've chopped socket off it and soldered to autocom screened lead, junction at the LHS of the headstock (touratech lead not shielded, just 2 wires.) Polarity preserved from both ends i.e red was 'tip' of the socket, blue socket barrel->autocom shield. All into socket A of part-57, then into the phone port on the active-7. Tried moving the audio lead away from the motronic/abs pump, no different. It sounds like 50/50% engine and quest cpu noise.
It was doing all this thru the Autocom speakers, but it's way more annoying thru the monitors. If you turn them down then the Zen's too quiet.
I'd reference all this to the phone, but can't find the sony lego block around the house. Can't get them in maplins easy these days either.
I think the only route is to put something inline from the quest to attenuate it and get the level closer to that of the phone/zen.
Any bright ideas? If I get this right the boosteroo goes on here.
Ian
<b>EDIT: The whine was the autocom right up against the battery. Moved it back an inch and it's fine, but will need wrapping plastic.
The noise from the quest is definitely coming out of it, as it changes as it does stuff, and doesn't get louder as you whack it up to say '4'.
Anyone got a circuit diagram for a simple volume pot on a 2 wire signal.?</b>
