Autoswitch Help!!!!
Paulbde
Norfolk, England
Autoswitch Help!!!!
Quote:
Originally Posted by ianboydsnr
this made it all clear for me
http://www.ukgser.com/forums/showthread.php?t=34417
Must be to many mince pies turning me into a thicko today, but can anyone help me out?
I have been following the instal document as per the link above, and I have fallen at the last hurdle.
I have all the wires connected, but am confused about the last 2.
It says brown - black ( relay/Autoswitch)
The thing that has me confused, is the wiring diagram with the switch says to connect the black wire from the autoswitch to the relay
whilst the installation guide above looks like you have to connect the black wire to the bikes loom, along with a brown wire?
so,
where does the black wire from the autoswitch go to?
do i need to connect the relay to this wire?
what is the brown wire?
Please help!!
Many thanks in advance
Paul
The Black Wire needs to go to a ground as does pin 85 on the relay, most of the brown wires in the fuse box go to ground.
So if you take the black wire to pin 85 then a wire from pin 85 to a brown wire in the fuse box.
Does this help?
