Axel nut size
Peak
England
Can anyone tell me the sizes of the front and rear axel nuts on a XChal? Could do with knowing but not near my bike at the mo. thanks
26mm IIRC
definitely 26mm
I have most of a 26mm spanner velcroed to the subframe under my seat. I cut off the open end of a combination spanner, grinding the end to the shape of a tyre lever.
26 ???
Man, I travelled 3000 km with my F650 / F800 tool kit which has a 24 socket for the back wheel. I would have looked like an idiot if I would have had a flat tire...
and what is the size of the front one?
26 ???
The F650/F800 are 24mm it's the G series that are 26mm
Thanks Micky. :thumb
considering my X is 7.000 km away, can you tell me if it is the same 26 back and Front? Also I noticed that on Xc there are no Torx bolts isn't it? they are all Allen hex wrenches?
On my 2007 G650XC the front and rear axle nuts are both 26mm :thumb
Some folk modify by fitting a machined down 24mm from a KTM but I just went out and bought a 26mm socket .... not a common size and not often found in a socket set :eek:
Yes ... all Allen bolts but they could have been changed by a previous owner so you'll need to look ;)
KTM are 27mm and fit fine, plus are 'closed' so no muck goes down the spindle & threads, however you have to machine the KTM nut for the front, because the KTM nut has a lip
KTM ones are 10 grammes lighter too:rolleyes::D
I wanted to buy a 26m socket 3/8 drive but no one seems to make one unless you know any different?
Don't think my rear wheel has been of since 2009!
Bloody thing was stuck solid I had to hammer it all the way and in the process knackered the end of the axle - I might just be able to save it ( or rather I'm hoping an engineer can)
It was rust in the axle spacer tube that caused it.
Also the alloy spacers on each side look very chewd up ( as though they at some stage been spinning and wearing away)
