GFJ Well-known member UKGSer Subscriber Joined Aug 20, 2010 Messages 954 Reaction score 67 Location Llandudno, N Wales May 6, 2015 #21 when I fitted some renthal's to my friends Sertao - we opted to drill the hole for the locating pin. Didn't cause any issues.
mikedefieslife Registered user Joined Jun 28, 2013 Messages 169 Reaction score 0 Location Somewhere in EU May 6, 2015 #22 It will weaken the bars a little, and means you can never move or relocate the controls.
Timolgra reformed Joined Sep 8, 2002 Messages 33,919 Reaction score 32 Location ..... May 6, 2015 #23 mikedefieslife said: What's the easiest pain free method to remove the pin? Note; there's no chance at all to pill it out with pliers. Click to expand... It's plastic, file or Dremel it off, if the switches move on the new bars wrap some taper around them.
mikedefieslife Registered user Joined Jun 28, 2013 Messages 169 Reaction score 0 Location Somewhere in EU May 6, 2015 #24 No the pins are metal. Dremelled the plastic away from the rear but the pin is still stuck tight. Trying to do as little damage as possible.
Losttheplot Well-known member UKGSer Subscriber Joined May 28, 2005 Messages 2,851 Reaction score 10 Location Hampshire,UK May 6, 2015 #25 GFJ said: when I fitted some renthal's to my friends Sertao - we opted to drill the hole for the locating pin. Didn't cause any issues. Click to expand... Same here. Think the renthal bars are much stronger than the OEM offerings. I drilled mine when i fitted the bars 7 years ago now, and despite being down on several occasions the bars don't seem to have suffered/
mikedefieslife Registered user Joined Jun 28, 2013 Messages 169 Reaction score 0 Location Somewhere in EU May 6, 2015 #26 I dremelled out the plastic bits holding the pins, but it's messy. Oh well, it can't be seen. Placed side by side with the oem bars the enduro bend is almost identical. Same height and sweep.
Robbo1961 Registered user Joined Aug 14, 2014 Messages 384 Reaction score 0 Location Southend on sea May 11, 2015 #27 Timolgra said: Oh..... . . . . . . . . . . . I'll let the rider tell the following incredable story Click to expand... Wow how did that happen ??
dean0n0 Registered user Joined May 15, 2012 Messages 9,542 Reaction score 1,964 Location Positive May 11, 2015 #28 Robbo1961 said: Wow how did that happen ?? Click to expand... Suspension bottoming out too much?
Robbo1961 Registered user Joined Aug 14, 2014 Messages 384 Reaction score 0 Location Southend on sea May 11, 2015 #29 Really it must have been the air shock then
BAKERMAN Well-known member UKGSer Subscriber Joined Jun 28, 2002 Messages 16,873 Reaction score 102 Location Andover Hampshire, Real ENGLAND May 11, 2015 #30 dean0n0 said: Suspension bottoming out too much? Click to expand... I hit the same hole, and just about held on.
Robbo1961 Registered user Joined Aug 14, 2014 Messages 384 Reaction score 0 Location Southend on sea May 11, 2015 #31 It looks like someone's cut it with a hacksaw !
