Mouse
I'm in the process of making a new bash plate for my 1200, and have been wondering about the way it's mounted. Normally the plate is attached to the sump by four rubber buffers, which are quite easy to break. Also this means any impact to the plate is transmitted to the engine through four distinct points, although presumably the engine case is designed with this in mind.
I was thinking of adding some more buffers to my new bash plate - possibly one in the centre of the bottom section, and one at the front. The front of the bash plate will be angled up more then the original to protect the exhaust pipe. The buffer at the front could probably rest against the angled front of the engine, just below the alternator belt cover.
The idea is that any impact to the plate will be transmitted to the engine over a wider area, and so would be less likely to cause damage. The extra font buffer would also protect the plate against being ripped off backwards to some degree. I'm not planning to attach these extra buffers to the engine, just bolt them to the bash plate and let them bump against the engine in the event of an impact.
The possible problem I can see is that, while the force will be lessened due to being spread out more, some of it will be transmitted to parts of the engine case that are not designed with this in mind. I plan on using quite soft rubber for these buffers, to allow the bash plate to deform in the event of a large impact, after all it is in the end a sacrificial device and if the plate is destroyed but the engine survives, it's done its job.
Has anyone got any thoughts on this? Is it a good idea or am I asking for a big hole in my sump?
Thanks for your input!
