- Joined
- Sep 27, 2002
- Messages
- 308
- Reaction score
- 1
I have read through the posts re batteries etc, and stripped the starter.. all greased / cleaned and magnets intact.
New Battery fitted in May, and pretty much from Day one the ABS does not kick in immediately but after a 10 min ride it will, 4K miles later and it has started to happen more frequently, and the clock has reset twice which is never a good sign.
The alternator is giving 14.4V on run, and I pop it on the optimate once a week.
I am used to this happening after 2 winters as the bike lives outside, but this is silly, it "nearly" didn't start the other week too.
Suggestions would be welcome, is there somewhere I can get it tested under load?.. I live in Greenwich, another option I guess would be to put the volt meter across it but to stop the engine firing whilst running the starter.. but how to stop it firing.
Thanks in advance for any suggestions, battery was from Sherlocks Excide Gel and would rather get it tested locally before paying silly money to send it back only to be told it is ok its a 19Ah Gel sealed affair.
ta
Paul
ta
Paul
