Bead Breaker - Small and Compact - Easy to USE
  • Thread starter Thread starter BMW and Motorcycle Spares
Hi, all, my friend does fabrication work and has made a few motorcycle tyre bead breakers suitable for moto x wheels and all other types of wheels up to a 160 width. Its simple to use, all you do put the breaker on either side of tyre next to bead and wind the nut in.
Below is a ebay link, if anybody would like a one i can send it to BMW fellow riders for £30 free postage.
I have one in my tool box for workshop use and my trail pack for when im out and about on the Yamaha WR, even if at moto x track.
Saves a major task of breaking tyre bead in the middle of no where, to fix your puncture
Ebay Linky Item No:- 110484068895, Not expensive and do the job.
Hope this helps a lot of people out.
Thanks Guys
Looks very good:thumb but I have no problem breaking the bead on a GS just using small tyre levers, it hurt your hands though:D
Breaking bead with tyre leavers, you must scratch death out your rims then.
You're right:blast...I'm just losing a battle with myself to spend £40:D
It's getting the bead back on the rim of a rear GS which is the real problem but found using a ratchet strap around the circumference helps if you're only carrying a small pump:)
i did it once
With lighter gas from a blowtorch, then chuck a match at it, it does work,but its proper scary,and is not for those with a nervous disposition and those without a fire extinguisher.
i tried the lighter gas thing, your right, its un nerving a bit...
the breaker looks a handy little thing, i use a thinned down spade myself, and jus jump on it, iv never used anything else,
Have I missed something or does it only do the front tyre on a GS?
It says up to 110 width on the advert, which is right please, 110 or 160? I have an offroader with 100 and 130 widths
Hi, it will do 160 tyres, as some 160 tyres only have a rim size width of 110mm or 11cm. Check the width of the rim not the size of the tyre width as this fits over the rim. I am able to get wider ones which will fit up to a 180 tyre. Hope this helps. Thanks David
New link to ebay item :- 110497027548 I will post to bmw members for £30 all in. Nice little bead breaker to put in your backpack incase you have a puncture as breaking tyre bead can sometimes be a nightmare. Not any more. If you would like one please email me.
Only 4 available.
Thanks David
