markjackson
I have never (since owning a pink Gilera Nordwest in about 1994) experienced forks as awful as those on my HP2e.
Their lack of brilliance was not unexpected, having read so many posts on the subject, but the level of awfulness was still a surprise. When fitted with supermoto wheels it was even worse,
A friend's KTM 950 Adventure shows that big tall bikes can work without a tele lever, when sprung and damped well and using WP forks so I snapped up the first pair of cheap ones he found me, just in case.
But...
I didn't want to give up on the standard forks without trying some basics, so tried 7.5 wt then 10wt in each leg, and played around between min and max damping settings...
Still far too saggy and confidence sapping, but I must confess to being quite well built, having a big petrol tank, oh... and I'm very fat!
I've had very productive results in the past by changing fork or shock springs to suit my 110kg, and they are sufficiently cheap to make it a sensible experiment before embarking on the WP conversion, so I ordered some 55kg/mm average rate progressive springs, and on removing the 'originals' found these were the same, so that didn't help.
Not to be beaten I took my existing springs to the local suspension guru (for him to measure etc) and he said they would be about right for my little trail bike, but miles off for a tubby fella, wanting a compromise between fast road/track SM wheels and Trailling on knobblies on the HP2 and recommended...
0.94kg/mm springs!
This is loads more than a 950ADV but about the same as a Superduke.
They havn't arrived yet, but I'm thinking I may use two of these for SM wheels and one new/one old (i.e average 72kg/mm) for the trail wheels.
So... Who has the highest fork spring weight and how heavy are you?
But...
0.94kg/mm springs!
try putting 115 psi in your rear schock its not possiblel at at a lot of garages so you will proberly have to use your hand pump to get it up to that ! ok good luck with your set up and keep us posted
