Benefits of an 18" rear over a 17"?
Dansin
Ombersley
I know tyre choice is supposed to be better but what else?
Bike is going for suspension work at the end of the week. Do I shorten the KYB forks to a standard Dakar length, or keep them 1/2" longer to match an 18" rear? :nenau
18" rear equals more tyre choice for aggressive going.
Always try to obtain as much suspension as possible, ie, your physical size is a good indicator.....
...plus it'll go over things a wee bit better.
Oh, and the tyres are easier to change, but again, fairly marginal.
For what you're using your bike for chap - tyre choice alone is plenty enough reason :thumb2
EDIT - also, an 18" makes the bike slightly higher geared - whether that's a good a bad thing is up to you.
I'm convinced. I think. :D
@ Mav - taking it to Mr Bancroft on Friday. He's suggested shortening the forks so I'll see what he thinks about keeping them longer to match an 18" rear. :thumb2
Give yourself options of dropping them in the yokes a bit, I often drop mine around 10mm on dirt bikes:)
Same here......but.......If he keeps his forks standard and goes up 1" at the rear that will prob have a similar effect to dropping the forks 10mm. It think; it is a bit early though and my head's not working yet :)
Andres
Andres
Yes, that's what I meant as Dansin has the choice of keeping them 1/2" longer to match the extra height with an 18" wheel, then he has the option of dropping them a touch ..... it must be too early:D
I hadn't even considered the gearing, I guess I can just drop to a 14T front to bring it back down.
Cool - you'll be pleased with results :thumb2
It's not that noticeable... just a slight edge of the acceleration.
Let me know when you're back on the road!
