Bevel box-swingarm bearing
Any good tool supplier will stock stuff from Sykes Picavant ( er! is that how you spell it ) ? Sykes do a kit or bits to fit standard two/three leg pullers.
What about expanding a rawlbolt in the bearing and then punching it out?
(Old wheelbearing trick)....
I did'nt bother with a puller either. Just heated that bad boy up with a hot air gun and drifted them out wth a punch. They came out soooo easy. Put he new bearings in the same way.
Find a socket of the correct diameter.
Insert socket in through driveshaft hole.
Connect socket extension arm to socket (through opposite side bearing hole).
Knock out.
