Yes .... You want to be able to drive through the corner, the last thing you want is to be stuck off the gas mid bend, (in too quick and unable to get on the power), so by judging your acceleration sense on the approach (and often, that means off the gas and floating towards the corner loosing a bit of speed) it then gives you the right speed to pick the drive up on the gas as you tip it in and drive through the bend.
