Does anyone here use one with a 1100/1150? Motorworks do. 350mm table, will it fit? I'm thinking if buying as we have a steep drive to the garage.
had a turntable for over 10years. still works perfectly. marvellous device. used with RT and GS. does exactly wot it says on the tin, but prob. comes in a box
That looks exactly the same as the one I made, a bit of PTFE spray / lube between the pieces helps too. Whatever you do try to keep the turntable as low as possible. The first one I made was 10mm high and hauling the R1100GS on to the centre stand on the turntable was much more difficult than on the floor.
