Bleedin brakes.
The Grinder
Heswall Wirral
:( Hello out there, Have recently got a M Reg R11R, but the resevoir has sprung a leak so fitted a new piston. But not happy with the end result long story . Has any body done the job before as iv,e tried every option to get the air from the system. Sort have done it know, but the ABS light won,t go out. I bled it from the unit so it seems ok no air bubbles but the brake still feels spongy. Cheers The Grinder.
Bleeding them backwards with a syringe of brake fluid from the nipple sometimes helps.
Might do better to post this in the tech section here:
http://www.ukgser.com/forums/forumdisplay.php?f=7
Good luck :beerjug:
