Yep I've got that bit, but according to manuel, "Remove grub screw and fit bleed valve" what bleed valve? where is it, in the tool kit? in a secret compartment,
It had me confused after years of messing with Triumphs and such, tied to the rhs fame at the rear is wot I thought was a breather, turns out this has a valve in it (probably a bearing on a spring) and to bleed the clutch you cut the tiewrap, undo the grub screw and put a special doobry in there. I didnt have one soooo, I pushed the little ball bearing in there down with an allen key while I got the missus to pump the clutch lever. That did the trick, no special tools needed or owt. Messy but simple.
Hodge
