Bleeding Brakes - The finale !!!
  • Thread starter Thread starter Bigfish1978
Bigfish1978
Hi, thanks to everyone for their help.
We used a combination of all the advice given - we did the brakes in the following order: :rob
Front Brakes:
1. Top up the resevoir on the handlebars
2. Top up the servo resevoir under the tank
3. Bled each caliper - topping up the servo resevoir as needed
4. Remove the ABS control plug as described in the PDF file
5. Bled each servo nipple in the order suggested in the PDF files.
Rear Brakes:
1. Top up the resevoir on the rear right of the bike
This took 2 of us about an one and a half hours but now we know what to do its easy and could be done in a hour or less on your own.
Secondly the brake light error sign idiot light - thanks once gain for your advice. You were right their was a gap in the lower filament about 1 hairs width wide - new buld - no light.
If anyone needs the PDF file e-mail me at :
[email protected] and i'll pass it on. :beerjug:
