mhsilverw
Hi,
I have searched the site and want to modify my R850GS - fitted with the "BMW low drivers Seat Pad" to be a bit lower - so I can get feet flat(ter) on the floor...
There seems to be 4 options...(maybe 5!)
1. Lower Shocks - front and rear......may look at this but 'er indoors rules out Ohlins, White Power or TechnoFlex...so it may be a HAGON pair...whilst the bike is used on roads (ie not off road) these might be OK - but a variety of posts suggests probs with leaks/quality
2. Paralever Torque Arm - I gather a lot of riders of the non-GS type have fitted the shorter arm from a GS onto others to raise height - does the converse work....so would an R850/1100/S/R/RT type fit (assume longer) on the GS? If so does this starin the shaft/Universal joint - and how much difference might this make?? As this would only effect the 'rear/height' assume this would alter the handling...mind you having an MZ and other bikes would I notice on the road?
3. Other BM shocks - would shocks off another model be lower/shorter and work as well as a custom made HAGOn / Ohlins type???
4. My seat is the lower/est BMW front seat pad - are there any lower available?
5. Whan I had a F650 I seemed to recall shock linkage changes...but assume nothing useful here or available for this.
Anything else I could consider...NHS leg extensions don't look likely and I would probably be in a waiting queue and a list somewhere...boot soles probably wouldn't work....
Help...
Help...
I did not really whant to take away the longer suspension travel and so on. I met Grant from Surtrim and he modified my seat.
The old foam was replaced with new firmer foam and reshaped to make it much lower. It turned out really nice!!! He will listen to your needs and offer advice on what will and won't work. You can even go there and pick your own colours and designs.
