BMW K100 K reg
ELIMINATOR
Hampshire.
A friend has this BMW K100 K reg. with an intermittent fault.
The starter motor will sometimes spin over without the key or anyone near the bike!
Anyone encountered this before ? A solution would be most useful:D
Change starter solenoid in the big plastic box under the rear of the fuel tank
I bet ya it happened once when the battery was really low??? It welded the starter contacts together a good "thump" on the box or rear of the tank can sometimes loosed it depending on how badly welded it is! Solution is to change it!
Once changed keep t'bike on a trickle charger (checking electrolyte levels regularly) and if it makes any sluggish startin sounds stop and get a car battery to jump from
Low volts = higher amps + welded / burned contacts!
Next :thumb
Nice try, but the key phrase was intermittent, I.e. not a welded up soleniod. This would be permanent:rolleyes:
IF it does it after he pushes the start button?????
Trust me on this eliminatin Dude I used to fix these for a livin at the local stealership!
The "burned" contacts are not letting the starter solenoid release
