Hi All,
Here is an H.I.D Xenon kit that was on my twincam 1200RT for a couple of thousand miles.
It is a plug and play set up with all connectors, gromets and plugs designed to be fitted without cutting cables.
There is a ballast for each bulb and a relay set up.
Bulbs 6000K H7 and rated at 35W.
Bulbs stored in their protective sleeves and the glass has never been touched by hand.
Ballasts measure 90x70x25mm each.
This is the canbus version so there were no issues.
I believe these are legal for use on motorcycles as the beam pattern is correct and they do not dazzle other road users.
I did not find an issue in this respect when I used them.
Asking £25 posted to UK address.
Thanks for looking
Thanks for looking
