BMW System 6 and bluetooth
Parki77
London, England
Hi,
I have just bought a system 6 helmet and was trying to find out what the best communication device is without paying and arm and a leg?
I had a scala rider G4 on my other helmet but have heard that it doesn't fit the system 6 very well.
I had the scala rider G4 converted so that I could use my custom in ear speakers.
I mainly what it so that I can listen to my Iphone 4 and answer a call if needed.
Many Thanks
I have a system 6 and have just put scala g9 onto it.
I used the glue pad option and the unit does have to mount a bit further back to avoid the sun visor slide. I found that on the system 6 helmet strap there is a loop holding the strap padding close to the strap, if the mic is fed through this loop it will position correctly and the loop holds it in the correct position.
Ian
