Hi All,
I've been having on and off trouble starting my '82 g/s over the last couple of months. Pressing the starter it would turn over, sound like it was trying to fire but wouldn't catch, and keep turning until the battery runs flat with that clack clack sound. Other times it would fire straight up, it would always restart once it had been on a run. After searching various threads, thought I would give the carbs an overhaul, as it had been about 4 years since they'd last been done, so I gave them a good ultrasonic clean, and a rebuild kit. But the problem remained.
The bike has a Siebenrock 1000 kit on it, and is twin spark plugged (which I would have thought would make it easier to start), with Dyna coils, it also has an odyssey battery, (all these mods are about 5 years/ 50,000 miles old and the battery is 8 years old).
I tried it again today, after having the battery on charge over night, and going through all the connections giving them a good clean/wire brush, and the same thing happened, i know it is a bit chilly at the moment, and everything needs to be tip top to get full cranking beans, so decided to swop the original Bosch starter motor over with a Valeo i have on a '78 project bike. I can only assume the Valeo is a recon or new starter, as coming from a '78 bike it looks very clean. Well, anyway I fitted it all up and after only 20 mins of charging time thought i'd give her a poke, and she fired up!!
...so, i suppose after all my rambling my questions are...
1. I know batteries have a certain life span, what's the life expectancy of a Hawker Odyssey? (as i've said mine's 8 years old).
2. I haven't had the Bosch apart to see what's worn, brushes etc, is it worth getting a recon one? is it up to cranking a 1000cc engine? or stick with the Valeo? i know the Bosch is heavier and doesn't spin up the engine as quick as the Valeo, but the Valeo, from what i've read doesn't seem to last as long as a Bosch (my Bosch has 85,000 miles on it).
I don't know the history of the Valeo i've just put on, so would like to get another to put on the bike (Bosch or Valeo), and keep this as a spare.
Cheers for any input,
over to you...
over to you...
