Re: replacement for tool tray thingy
rockhopper said:
their is a company over the pond that does a replacement for the tool tray and plastic cover that give you a lot more room for toys and also a steel cover for the area under the pillion pad. I think they are called BEST REST PRODUCTS or something similarChris
Chris,
I Emailed Best Rest & asked them about their kit as follows:
Hi,
I've just fitted a standard 1150GS rack & seats to my 1150GS Adventure. In doing so, I've lost the space under the seat where I fitted my Icom bike-to-bike radio. The logical place to re-locate it seems to be the tool tray area under the passenger seat. I've read your description of your replacement tool try & cover. Can you answer a few questions:
1. What is the lid made of?
2. What are the internal dimensions of the 'tool tube' & what is it made of?
3. How is the tool tube held in place?
4. Do you make, or are you aware of anyone else who produces, a similar tray to the OE one, but without the 'fitted' mouldings to hold the tools?
5. Can you think of any other way I can adapt the space to hold my radio & make it waterproof?
MikeO
Mike -
1. Lid is .125" aluminum with a black powdercoat finish
2. Tube is 2" x 8". Clear acetate body, red vinyl end caps. It's waterproof when closed.
3. It rests along the right side of the frame. It doesn't move around because it nestles against the frame rail.
4. No
5. Any under the seat mounting will not guarantee a waterproof setting. In fact, even the stock BMW plastic tray has drain holes in the bottom, they wouldn't be there unless there was a reason. I'd wrap the radio in two heavy duty zip-lock bags and seal them with duct tape, sealing the antenna and power leads as they exit the bags. The only other idea I have about radio mounting is to put it in the tankbag, if you have one.
David
BestRest Products, LLC
David Petersen, Manager
6908 - 220th St. SW
Mountlake, Terrace, WA 98043
(425) 673-1023
(425) 673-0502 (fax)
http://www.bestrestproducts.com
BestRest Products
I also had a reply on another thread from someone who had bought this kit and thought it was pants - offering to give it away! It's totally unsuitable for a bike to bike radio (having a metal lid). Since my last post I've cut out the bottom of the tool tray* & there's plenty of room to fit the radio &, I should think, an Autocom. the lid still fits securely (well, as securely as it ever did
). I'm going to get some quality heavy duty polythene bags tomorrow to double wrap & tape it all up, as described above & I'll let you know how I get on....
MikeO
*Top Tip - Leave the tooltray in hot water for a few minutes before cutting it with a Stanley knife - Piece of old ease
