sani Registered user Joined Jul 29, 2007 Messages 1,890 Reaction score 0 Location London Oct 15, 2008 #1 Hi Guys When is the time to change the Brake Disc's?
Noddy Some sort of clique thing UKGSer Subscriber Joined Sep 7, 2004 Messages 5,700 Reaction score 2 Location Thetford, Norfolk, England Oct 15, 2008 #2 When you can't stop but you should have.
Aidan1150 Nice but unfortunate husband. Moderator Moderator Joined Nov 17, 2004 Messages 15,052 Reaction score 4,027 Location South Armagh, Ireland Oct 15, 2008 #3 sani said: When is the time to change the Brake Disc's? Click to expand... Once the disc thickness gets to 4.5mm, which is the minimum recommended thickness then it is time to change them. You can check the thickness with a micrometer. HTH
Colban Registered user Joined Jul 28, 2006 Messages 2,872 Reaction score 1 Location Lincoln. Oct 15, 2008 #4 sani said: Hi Guys When is the time to change the Brake Disc's? Click to expand... When A;you have uneven braking caused by warped discs or B;when the MOT man tells you to.Dont forget to replace the pads as well.
spot Registered user Joined Mar 7, 2006 Messages 223 Reaction score 0 Location Sheffield England Oct 16, 2008 #5 I put 30,000 miles and 2 mot's on mine after bmw told me they needed replacing with no problems atall.
Steptoe Him/Bloke/Fella. UKGSer Subscriber Joined Oct 12, 2003 Messages 73,608 Reaction score 22,123 Location S/W London. Oct 16, 2008 #6 When they get as thin as a biscuit tin lid .
davegs Well-known member UKGSer Subscriber Joined Jul 18, 2006 Messages 9,243 Reaction score 374 Location bromley Oct 16, 2008 #7 discs When the disc stops and the wheel dosent!"
sani Registered user Joined Jul 29, 2007 Messages 1,890 Reaction score 0 Location London Oct 16, 2008 #8 Thanks Guys
