Brake dust seal question?
david vaughan-birch
Denstone Staffs
Anyone know if its possible to remove, clean and refit the dust seals on brembos without removing the pistons? They're a bit sticky and could do with a clean I think!
hi david
you have to remove the pistons to get to the seals
do one at a time
do not split the brakes in 2 as the brakes will not seat and work right
its a pain but once out the brake will work much better.
try doing vavles on gt1200
:blast
I'm confused by the original question - "piston seals" - yep - at the base of the piston obviously.
You asked about dust seals - can only think of the rubber gaitor things on the rear caliper.
Can you add some light?
