Thanks it is on continuousChat gpt says ;
common scenarios:
1. Flashing Brake Failure Light (at low speed):
• This is normal if the bike is just starting up and the ABS system hasn’t yet performed its self-check, which typically happens after you reach a speed of about 5 mph.
2. Steady or Continuous Flashing Brake Failure Light:
• This suggests a fault in the ABS system or another braking issue. Common causes include:
• Low brake fluid levels.
• Worn brake pads.
• A faulty ABS sensor.
• A damaged ABS control unit.
3. Brake Failure Light Combined with No ABS Function:
• This indicates the ABS system has been disabled due to a fault, but the brakes will still function conventionally without ABS. Exercise caution, especially in wet or slippery conditions.
If the light does not go off after starting or it stays on continuously, it is crucial to inspect the braking system. Check the brake fluid level and look for visible issues like leaks or worn pads. If the problem persists, it’s best to have the bike inspected by a BMW-certified mechanic to ensure safe operation.”
Do refer to workshop manual though
I think the ABS light is a separate light this lit up red letters saying brake failureFinally is it an ABS failure light ?
That will also come on if you’ve accidentally disabled the ABS
Thankshit the pump motor on the ABS module - brushes seized (as they designed it) - if like drilling holes accurately its a DIY job otherwise fight the module and send off for repair
one place https://www.ecutesting.com/product-catalogue/bmw/r1200gs/abs-pump-ecumodule-combined/
Ye Speedo still worksDoes the speedo still work? Sometimes the rear abs failing can bring up the abs light as i believe it uses this to detect speed as well. This is from what I've read on forums etc, never actually had it happen to me.
Happy to be corrected if I'm wrong![]()
Thanks for your input a friend of mine who has a GS is bringing a code reader over in a few weeksOh well, that's one thing of the list anyway I guess lol. Can you get the codes read? May help narrow it down?
forums.bmwmoa.org
Interesting thanks do you know what year fiestaWhen you plug the GS911 in, if you get the fault "ABS pump fault, interrupted power supply to ABS pump",
Then you will likely be needing the fix as mentioned by Botus in post number 7 above. If you are handy with the spanners, then it can be fixed very cheaply with an ABS pump from a Fiesta. There are several vids on YouTube showing how to do this.
Brilliant thank youI posted a thread when mine played up, here is the result after I fixed it, good luck with getting yours sorted
"Now Fixed
Thanks for the advice, and for anyone browsing the thread looking how to fix their bike, heres my take on the subject:
First and foremost, if you get the brake failure light coming on, get the fault codes read by a dealer/friendly GS911 owner. This fault cropped up shortly after replacing the brake discs when conventional wisdom would have pointed me in the direction of the wheel sensors.
You will need to remove your ABS unit, remove the faulty pump from it, repair or replace it, re-fit and ride!
I chose to fit a used pump from a Fiesta.
The Ford Fiesta part number you need is CV21-2C405-AE. There are vids on YouTube of how to do this so I'm not going into detail of what to do
(edited to remove obsolete Youtube link)
What I will add is that before you start, drain the brake fluid, it will save a lot of mess. Just open the bleed nipples on all 3 calipers, remove the reservoir filler caps and pump out the fluid until the reservoirs are empty then leave it to drain a bit longer.
When I put it back together, the front brakes bled quite easily and I soon had pressure at the lever. The rear was a bit more involved, I had to loosen the "fluid out" banjo bolt on the ABS module and bleed from there to get all the air out so fluid would then flow to the caliper.
Test rode the bike yesterday morning and all was well. Fixed for a £40 used pump and a bottle of brake fluid."
