Brake light
Bronco Billy
Coalville
It dont come on when I presses the brake pedal but does when I presses the front lever. What up and how do i fix it? Tar muchly.
BB
It'll be your rear brake light switch. Switch is located on the rear brake footrest hanger, plugs into the loom up on the R/H side subframe rail.
Have a poke around first before buying one, the switch can sometimes get caught/jammed.
Thanks Neil, Bikes not been used for a while (2 year old boy). It was poking around in the first place that led to the bike not being used for a while :D
Congratulations :beerjug: Still life in the old dog yet :D
Just a reply for those who may come across the same fault, with Neils advice i had a poke around the right hand side footpeg hanger. Follow the route of the wire and it leads to a micro-switch. When the brake pedal is pressed it releases a small metal spring strip that holds in a tiny button on the micro-switch. Squirted some wd40 on it and and got it to work with jiggling it about. Saved me buying a new switch or even worse paying someone to fix it for me. :thumb
