Brake line extension?
My opinion, up straight 25mm perfect for riser no problems cable, up back 40mm now become a little tighter depend on bar position, bar more forward give more brake cable, bar more back and low make very tight, so if bar back low and feel to tight, my opinion better like post 2 say buy longer cable to be safe and happy.
EDIT: just had a closer look - the line is crimped into a block as part of the ABS system so it would need to be some sort of simple banjo extender...
FWIW I've used Hel several times and found them to be competitive in pricing but outstanding in customer service. Ring and ask, they really are very good.
Thanks, blooming pricey though when you can get a whole custom Hel line to order for less!
Thanks, will call them.
