Brake tubing clip: where??
John Roberts
North Wales
I just had a new section of brake tubing that goes from the rear master cylinder to the hose on my '82 R100RS, it's routed under the battery carrier and it came with this little white plastic clip. Where does it go?
By the way, this is not the clip to attach the flexible hose to the swing arm.
EDIT: Sorry, it's routed sort of around the base of the battery carier rather than under :blast
Hi
It is a clip to attach the hose to the swing arm. :) Apparently they come in two designs, a black one and a white one. Yours is a white one.
See Motorworks part number BRA38089
Steve
Thanks, Steve, but I just had a look at the one you mentioned and Motorworks have got it wrong, I've got the black and the white clips, the BLACK one is the HOSE/swing arm one, the hole where it grips the hose is at a guess, 10/12mm, i.e. hose size and the other white one has its hole 5mm in diameter- the size of the metal tubing. I may give Motor Works a bell, their catalogue photo is the wrong one.
EDIT, photos of both. :thumb2
