Russ
remarkably similar to politicians then!
In fact i wonder if journos are failed politicians?
Russ said:remarkably similar to politicians then!
No they didn't quote distances. However, I would be extremely surprised if the stopping distances weren't in inverse proportion to the time. The braking characteristics i.e. decelleration vs speed will be similar for all machines - none of them have a different type of brake i.e. carbon fibre, drum, etc.Kropotkin said:Did they also have braking distances? These can be different to braking times, and a shorter braking time is not necessarily a shorter braking distance. (It has to do with deceleration).
I'd be interested in seeing the braking distances.
Russ said:I think its down to the linked braking system, as my VFRs (all of them) wouldn't stand up as easily when braking in a bend than a sports bike.
Russ said:I think the linked braking adds to the effect of taking the weight away from the nose, meaning the bike is less inclined to tuck under as the suspension is compressed altering its geometry
Yeah, I'm sure you're right - didn't study the article in detail as I think they were going to kick me out of WHSmiths, as I'd already read, Bike, Ride, Fast Bikes and was just moving to MCNChisurz said:Mouse, that story was also in Bike (February 2005), though I think the R1200GS reference is an error as the story starts of quoting Sean Hayes saying "some years back". So there can now be some debate over which version of ABS works that well in corners...
The rest of the article in Bike about Honda's move towards ABS on their range... It notes near the end that "BMW's servo-assisted ABS is a far more complicated affair...".![]()
GSmonkey said:Yeah, I'm sure you're right - didn't study the article in detail as I think they were going to kick me out of WHSmiths, as I'd already read, Bike, Ride, Fast Bikes and was just moving to MCN![]()
GSmonkey said:Check out these brake test results against pretty stiff competition (make sure if you've got a mate on a fireblade he rides in front of you!!):
Must admit looking at it again it does look dodgy that the blade outbrakes the Hornet.TerryM said:Monkey,
The spread is so wide between similar bikes all competing for sales that I think the journos have got it wrong somewhere.
Probably just loaded data from spreadsheets/charts having different values on the axes. Otherwise someone would have been shouting about his Kwak outbraking Blades by light years.
Terry
