Mouse
Gipsy said:Don't forget 607's now not available in Z rating. At least not the last time I checked.
Does it matter though? The next rating down (V? I forget) is fine for the alleged 130mph top speed of the 1200GS. And if you never go above 100 (I don't, honest) you can fit "Q" rated tyres, should you need to.
Maybe it's because I have the rear preload fairly high and this improves ground clearance enough to keep the footrests away from the tarmac. Anyway, the bike's brilliant on 020's - highly recommended.
