Tank I got came with a one fuelpump assembly mount bolt broken. See the pics below.
I haven't tryed to see if it holds fuel w/o leaks when I fix it leaving one bolt unfixed, but I rather have all the bolts available...
So what do you reckon is the best way to fix that one particual broken bolt?
I had a thought of drilling the old bolt out, puting a new one in from inside the tank and sealing with EPOXY? Any other ideas?
TIA, Margus
TIA, Margus
Mine came like that too. Actually, I stand corrected, mine is the one on the very bottom of tank. It's being repaired as we speak and yes silicone does work but surely it will react with the petrol if not used judiciously?
