Swirling clouds of metal debris in the gearbox oil
Swirling clouds of metal debris in the gearbox oil![]()
It's the big chunks of metal you really need to worry about...
Uh oh
Full rebuild coming up![]()
I've got a rebuilt spare ready to go so not that much of a problem.
The butchers bill for this one is:-
Fifth Gear - £99 + Vat
Output shaft - £265 + Vat
Intermediate Helical gear - £128 + Vat
Full set of bearings, seals etc - £132 + VAt
Comes to around £750 so this box is scrap.
Outch
Is it scrap simply because of the costs, or because the shaft/bearing seats will be buggered?
BTW Rob, Is it possible to fit lower ratio first and second gears in these boxes?
Val.
Is it not worth keeping for any of the bits that aren't knackered, i.e. the casings? You might be able to make a good one out of two perhaps.
Suggested cause of problem was determined as worn swivel bearings on the final drive/ bevel box. The achilles heel of the paralever, according to both Gary Burton, his gearbox rebuild man, and Steve Scriminger.
