Can you fit HID to a 1200?
Les Wassall
HiD50.com leading light in HiD
Cheshire
Most probably asked before, but I've not found any threads so can you fit a HID to a 1200 or are the lights good enough without, fitted a hid to my 1150 and a great improvement.
As I'm toying with the idea to change to the 12, wondered if it's worth taking the hid of mine and putting it on a 12.
Also what bulbs do the 1200 use in the lights? H1?
Try looking at this article
http://www.r1200gs.info/howto/BR-mount.html
Stig
Thanks for that Stig, if I explain myself a little better, can you convert the headlight of the 1200 to take a HID.
Here in Belgium several already installed a xenon conversion kit in their R1200GS. The canbus system does not have a problem with the reduced power consumption (35W iso 55W)
You will need a H7 kit, so you can't use your H1 kit from the R1150GS.
This is one of the guys who did the conversion
Remark: It is however a problem on a R1200RT because you need to replace two bulbs. The canbus systems does have a problem with the power consumption of only 70W iso 110W. Only to be solved by starting the bike 2 or 3 times.
Thanks for that guys, answers my question, will see if I can buy a replacement bulb for my HID kit.
:thumb
