Can you reset the "Call Home" no?
Eyewitness
Hi all
Is it possible to reset the number you've set for the "Call Home" button in the phone function of a Zumo 550?
When I was pairing my phone etc, I inadvertently, stupidly set the "Call Home" no as my mobile no, not my landline....doh!
I've tried resetting different options but can't seem to delete or find an option to reset this function.
Any advice would be much appreciated!
Thanks in advance,
Terry:blast
I finally found the answer on the Garmin site. Seems obvious now but previously being a Tom Tom user for about four years functions on the Zumo seem in odd places.
Here the solution if anyone else needs it!:
To change the home phone number:
Turn on the unit.
From the Main menu, touch Where to?.
Touch Favorites.¹
Touch Home.
In the bottom right corner of the screen, touch Edit.
Touch Change Phone Number.
Change the phone number and touch Done.²
The home phone number is now changed.
Notes:
1. Some models may require you to press My Locations before selecting Favorites.
2. After touching Done, some models may require you to touch OK to apply the change.
:aidan
