veefour
Hi guys
Bought one of those niffty USB charging sockets and a canbus lead for the auxillary socket under the oil cooler (2010 GS). Before fitting the socket I thought I'd just check the voltage on the lead to make sure I'm in the right socket after reading another thread that says there's a diagnostic one near there (although I can't see it).
Anyway using wires 1 and 3 as per the dealers instructions I get good voltage on the multimeter when I put the ignition on which it holds for about 2 minutes when I turn it off. I thought I read somewhere it stays on longer than that? Also when it turns 'off' I'm still reading just over 1V on the meter - is that right?
Thanks in advance.
Thanks in advance.
It's a Garmin Nuvi car sat nav rather than a purpose made bike one as I only want to use it occasionally but clearly one of the pins on the USB lead tells it its connected to a computer rather than just a charger and whilst it's in that mode you can't use it as a sat nav.
