Reading the Haynes manual, after an engine overhaul I need to bleed the oil system. I can't get the bleed screw out from behind the filter, it seems stuck fast.
Can I just bleed through to the oil return pipe, or will I end up with an air lock somewhere if I don't do that first bleed step?
Any advice appreciated. The bikes been off the road for months and I'm itching to start her up!!
