Carb stripping/cleaning and re-assembly
Sunny Jim
Haworth
Sunny Jim
Great find I will have to download them
Eddie
it's probably the float needle sticking, or got a bit of dirt in it.
no need for disassembly, just tap it lightly with a mallet until it stops ;)
Read that elsewhere Cookie but knowing my luck I'd break the chuffing thing:eek
Love and kisses to you and Angie
J & P
x
just a light tap or two with a soft faced mallet would probably do it. i've kicked them before with bike boots if it's happened while i'm out. you can tell i'm a guzzi owner, can't you? :D
look forward to seeing you both again some day :)
Turn the fuel off and then take the float bowl off, hold the float up and then turn the fuel on, drop the float and let it run for a second. Lift the float and then turn the fuel off.
It's generally just grit from the tank getting stuck under the needle. if it persists then you may need to flush the tank or check that your floats not sinking.
Aye Cookie - would be good to quaff a glass or two with some of that 'special' cake.
Rob - thanks for that - will start there. Really fancy cleaning the bodies up though - what do you think he soaked them in when off camera?
Jim
